-------------- Astec Tutorial -------------- Tutorial installation ===================== Requires git. Astec tutorial can be found at gitlab.inria.fr/astec/astec-tutorial. It can be downloaded with .. code-block:: bash git clone https://gitlab.inria.fr/astec/astec-tutorial.git Tutorial data ============= The directory ``/path/to/astec-tutorial/``, also denoted by ``path/to/experiment/`` or ````, contains the ``RAWDATA/`` and ``parameters/`` sub-directories and a ``README`` file .. code-block:: none /path/to/astec-tutorial/ ├── data/ │ ├── LC/ │ │ └── ... │ └── RC/ │ └── ... ├── ... ├── parameters │ └── ... ... The ``data/`` contains 21 time points (indexed from 0 to 20) of subsampled (for file size consideration) raw data from a 3D+t movie acquired by a MuViSPIM microscope. :: /path/to/experiment/ ├── data/ │ ├── LC/ │ │ ├── Stack0000/ │ │ │ ├── Time000000_00.mha.gz │ │ │ ├── ... │ │ │ └── Time000020_00.mha.gz │ │ └── Stack0001/ │ │ ├── Time000000_00.mha.gz │ │ ├── ... │ │ └── Time000020_00.mha.gz │ └── RC/ │ ├── Stack0000/ │ │ ├── Time000000_00.mha.gz │ │ ├── ... │ │ └── Time000020_00.mha.gz │ └── Stack0001/ │ ├── Time000000_00.mha.gz │ ├── ... │ └── Time000020_00.mha.gz ... where ``LC/`` and ``LC/`` stand respectively for the left and the right cameras. Fusion ------ We assume that we are located in the directory ``/path/to/astec-tutorial/``. Running the fusion is done with |fusion| .. code-block:: bash $ astec_fusion -p parameters/1-fuse-tutorial-parameters.py ``1-fuse-tutorial-parameters.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-fusion`). .. code-block:: python :linenos: :caption: parameter file for the fusion step. :name: fig-tutorial-parameter-fusion PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 DIR_RAWDATA = 'data' DIR_LEFTCAM_STACKZERO = 'LC/Stack0000' DIR_RIGHTCAM_STACKZERO = 'RC/Stack0000' DIR_LEFTCAM_STACKONE = 'LC/Stack0001' DIR_RIGHTCAM_STACKONE = 'RC/Stack0001' acquisition_orientation = 'right' acquisition_mirrors = False acquisition_resolution = (1., 1., 1.) target_resolution = 1.0 * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``data/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the result fusion images will be named. * The variables ``begin`` and ``end`` set respectively the first and the last index of the input time points to be processed. * The variable ``DIR_RAWDATA`` is the directory containing the raw data. * The variables ``DIR_LEFTCAM_STACKZERO``, ``DIR_RIGHTCAM_STACKZERO``, ``DIR_LEFTCAM_STACKONE`` and ``DIR_RIGHTCAM_STACKONE`` set the sub-directories of the ``data/`` directory, where the 4 acquisitions of the SPIM microscope are located. * The variables ``acquisition_orientation`` and ``acquisition_mirrors`` are parameters describing the acquisition geometry. * The variable ``acquisition_resolution`` is the voxel size (along the 3 dimensions X, Y and Z). * The variable ``target_resolution`` is the desired isotropic (the same along the 3 dimensions) voxel size for the result fusion images. After processing, a ``FUSE/`` directory has been created .. code-block:: none /path/to/astec-tutorial/ ├── FUSE/ ├── data/ ├── ... ├── parameters ... The ``FUSE/`` directory contains .. code-block:: none FUSE/ └── FUSE_RELEASE/ ├── 2019-Tutorial100_fuse_t000.mha ├── ... ├── 2019-Tutorial100_fuse_t020.mha └── LOGS/ The fused images are named after ``_fuse\t.mha`` (where ```` denotes the value of the variable ``XXX``) and indexed from ```` to ```` (as the input data). The directory ``LOGS/`` contains a copy of the parameter file (stamped with date and hour) as well as a log file (also stamped with date and hour) reporting information about the processing. .. _tutorial-intra-registration-fuse: Sequence intra-registration (or drift/motion compensation) [1] -------------------------------------------------------------- We assume that we are located in the directory ``/path/to/astec-tutorial/``. Running the sequence intra-registration is done with .. code-block:: bash $ astec_intraregistration -p parameters/1.5-intraregistration-tutorial-parameters-fuse.py ``1.5-intraregistration-tutorial-parameters-fuse.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-intra-registration-fuse`). .. code-block:: python :linenos: :caption: parameter file for the motion compensation step. :name: fig-tutorial-parameter-intra-registration-fuse PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``FUSE/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variables ``begin`` and ``end`` set respectively the first and the last index of the input time points to be processed. After processing, a ``INTRAREG/`` directory has been created .. code-block:: none /path/to/astec-tutorial/ ├── FUSE/ ├── INTRAREG/ ├── data/ ├── ... ├── parameters ... The ``INTRAREG/`` directory contains .. code-block:: none INTRAREG/ └── INTRAREG_RELEASE/ ├── CO-TRSFS/ │ ├── 2019-Tutorial100_intrareg_flo000_ref001.trsf │ ├── ... │ └── 2019-Tutorial100_intrareg_flo019_ref020.trsf ├── FUSE/ │ └── FUSE_RELEASE/ │ ├── 2019-Tutorial100_intrareg_fuse_t000.mha │ ├── ... │ └── 2019-Tutorial100_intrareg_fuse_t020.mha ├── LOGS/ ├── MOVIES/ │ └── FUSE/ │ └── FUSE_RELEASE/ │ └── 2019-Tutorial100_intrareg_fuse_t000-020_xy0205.mha ├── TRSFS_t0-20/ │ ├── 2019-Tutorial100_intrareg_t000.trsf │ ├── ... │ ├── 2019-Tutorial100_intrareg_t020.trsf │ └── template_t0-20.mha ├── ... ├── 2019-Tutorial100_fuse_t020.mha └── LOGS/ * The directory ``CO-TRSF/`` contains the co-registration transformations. * The directory ``FUSE/FUSE_RELEASE/`` contains the resampled fused images in the same geometry (images have the same dimensions along X, Y and Z), with drift compensation (the eventual motion of the sample under the microscope has been compensated). * The directory ``MOVIES/FUSE/FUSE_RELEASE/`` contains a 3D (which is a 2D+t) image, here ``2019-Tutorial100_intrareg_fuse_t000-020_xy0205.mha``, which the #205 XY-section of the resampled fused images for all the time points. * The directory ``TRSFS/`` contains the transformation of every fused image towards the reference one as well as the template image (an image large enough to including each fused images after resampling). The template image ``template_t0-20.mha`` is of size :math:`422 \times 365 \times 410` with a voxel size of 0.6 (the voxel size can be set by the variable ``intra_registration_resolution``). Segmentation of the first time point ------------------------------------ We assume that we are located in the directory ``/path/to/astec-tutorial/``. Segmenting the first time point is done with .. code-block:: bash $ astec_mars -p parameters/2-mars-tutorial-parameters.py ``2-mars-tutorial-parameters.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-mars`). .. code-block:: python :linenos: :caption: parameter file for the segmentation of the first time point. :name: fig-tutorial-parameter-mars PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``FUSE/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variable ``begin`` sets the index of the first input time point (to be processed). After processing, a ``SEG/`` directory has been created .. code-block:: none /path/to/astec-tutorial/ ├── FUSE/ ├── INTRAREG/ ├── SEG/ ├── data/ ├── ... ├── parameters ... The ``SEG/`` directory contains .. code-block:: none SEG/ └── SEG_RELEASE/ ├── 2019-Tutorial100_mars_t000.mha └── LOGS/ ``2019-Tutorial100_mars_t000.mha`` is the segmented first time point of the sequence. Correction of the first time point segmentation ------------------------------------------------ We assume that we are located in the directory ``/path/to/astec-tutorial/``. Correcting the first time point segmentation is done with .. code-block:: bash $ astec_manualcorrection -p parameters/3-manualcorrection-tutorial-parameters.py ``3-manualcorrection-tutorial-parameters.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-manual-correction`). .. code-block:: python :linenos: :caption: parameter file for the segmentation correction of the first time point. :name: fig-tutorial-parameter-manual-correction PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 mancor_mapping_file='parameters/3-manualcorrection-tutorial.txt' .. code-block:: none :linenos: :caption: parameter file for the segmentation correction of the first time point. :name: fig-tutorial-parameter-manual-correction-txt 4 9 10 6 20 13 23 30 12 21 40 29 41 37 51 42 45 44 57 61 59 62 65 66 65 74 78 67 72 76 77 82 83 75 * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``SEG/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variable ``begin`` set the index of the first input time point (to be processed). * The variable ``mancor_mapping_file`` gives the file name containing the correction to be applied. After processing, the ``SEG/`` directory contains .. code-block:: none SEG/ └── SEG_RELEASE/ ├── 2019-Tutorial100_mars_t000.mha ├── 2019-Tutorial100_seg_t000.mha ├── LOGS/ └── RECONSTRUCTION/ ``2019-Tutorial100_seg_t000.mha`` is the corrected version of the segmentation obtained at the previous step. .. _tutorial-segmentation-propagation: Segmentation propagation ------------------------ We assume that we are located in the directory ``/path/to/astec-tutorial/``. Segmenting the first time point is done with .. code-block:: bash $ astec_astec -p parameters/4-astec-tutorial-parameters.py ``4-astec-tutorial-parameters.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-astec`). .. code-block:: python :linenos: :caption: parameter file for the segmentation propagation. :name: fig-tutorial-parameter-astec PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 result_lineage_suffix = 'pkl' After processing, the ``SEG/`` directory contains .. code-block:: none SEG/ └── SEG_RELEASE/ ├── 2019-Tutorial100_mars_t000.mha ├── 2019-Tutorial100_seg_lineage.pkl ├── 2019-Tutorial100_seg_t000.mha ├── 2019-Tutorial100_seg_t001.mha ├── ... ├── 2019-Tutorial100_seg_t020.mha ├── LOGS/ └── RECONSTRUCTION/ ``2019-Tutorial100_seg_lineage.pkl`` is a pickle python file containing a dictionary (in the python sense). It can be read by .. code-block:: $ python ... >>> import pickle as pkl >>> f = open('2019-Tutorial100_seg_lineage.pkl', 'r') >>> d = pkl.load(f) >>> f.close() >>> d.keys() ['cell_lineage', 'cell_volume'] In this pickle file, cells have an unique identifier :math:`i * 1000 + c`, which is made of both the image index :math:`i` and the cell identifier :math:`c` within a segmentation image (recall that, within an image, cells are numbered from 2, 1 being the background label). .. _tutorial-intra-registration-seg: Sequence intra-registration (or drift/motion compensation) [2] -------------------------------------------------------------- We assume that we are located in the directory ``/path/to/astec-tutorial/``. Running the sequence intra-registration is done with .. code-block:: bash $ astec_intraregistration -p parameters/1.5-intraregistration-tutorial-parameters-seg.py ``1.5-intraregistration-tutorial-parameters-seg.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-intra-registration-seg`). .. code-block:: python :linenos: :caption: parameter file for the motion compensation step, segmentation images being used to build the template. :name: fig-tutorial-parameter-intra-registration-seg PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 EXP_INTRAREG = 'SEG' intra_registration_template_type = "SEGMENTATION" intra_registration_template_threshold = 2 intra_registration_margin = 20 intra_registration_resample_segmentation_images = True intra_registration_movie_segmentation_images = True * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``FUSE/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variables ``begin`` and ``end`` set respectively the first and the last index of the input time points to be processed. * the variable ``EXP_INTRAREG`` set the suffix of the sub-directory of the ``INTRAREG/`` directory to be created. * the variable ``intra_registration_template_type`` set the images to be used to build the template. Here, since it is equal to ``'SEGMENTATION'``, they are the segmentation images obtained at the previous step. The variable ``intra_registration_template_threshold`` set a threshold to be applied to the template images to define the information to be kept: we want all the points with a value equal or greater than 2 to be contained in the template after resampling. Since cells are labeled from 2 and above, the template is designed to contain all labeled cells after resampling, so it is built as small as possible. The variable ``intra_registration_margin`` allows to add margins (in the 3 dimensions) to the built template. * The variable ``intra_registration_resample_segmentation_images`` indicates whether the segmentation images are to be resampled in the template geometry. * The variable ``intra_registration_movie_segmentation_images`` indicates whether 2D+t movies have to be built from the resampled segmentation images. After processing, a ``INTRAREG/INTRAREG_SEG/`` directory has been created and the ``INTRAREG/`` directory now contains .. code-block:: none INTRAREG/ ├── INTRAREG_RELEASE/ └── INTRAREG_SEG/ ├── CO-TRSFS/ │ ├── 2019-Tutorial100_intrareg_flo000_ref001.trsf │ ├── ... │ └── 2019-Tutorial100_intrareg_flo019_ref020.trsf ├── FUSE/ │ └── FUSE_RELEASE/ │ ├── 2019-Tutorial100_intrareg_fuse_t000.mha │ ├── ... │ └── 2019-Tutorial100_intrareg_fuse_t020.mha ├── LOGS/ ├── MOVIES/ │ ├── FUSE/ │ │ └── FUSE_RELEASE/ │ │ └── 2019-Tutorial100_intrareg_fuse_t000-020_xy174.mha │ └── SEG/ │ └── SEG_RELEASE/ │ └── 2019-Tutorial100_intrareg_seg_t000-020_xy174.mha ├── SEG/ │ └── SEG_RELEASE/ │ ├── 2019-Tutorial100_intrareg_seg_t000.mha │ ├── ... │ └── 2019-Tutorial100_intrareg_seg_t020.mha ├── TRSFS_t0-20/ │ ├── 2019-Tutorial100_intrareg_t000.trsf │ ├── ... │ ├── 2019-Tutorial100_intrareg_t020.trsf │ └── template_t0-20.mha ├── ... └── LOGS/ In addition to directories already described in section :ref:`tutorial-intra-registration-fuse`, the ``INTRAREG_SEG/`` directory contains * The directory ``SEG/SEG_RELEASE`` contains the resampled segmentation images in the same geometry (images have the same dimensions along X, Y and Z), with drift compensation (the eventual motion of the sample under the microscope has been compensated). * In addition to a 2D+t movie made from the resampled fusion images, the directory ``MOVIES/`` contains a 2D+t movie made from the resampled segmentation images in the sub-directory ``SEG/SEG_RELEASE``. * The template image ``template_t0-20.mha`` in the directory ``TRSFS/`` is now of size :math:`323 \times 265 \times 348` with a voxel size of 0.6, which is smaller than the one computed in section :ref:`tutorial-intra-registration-fuse`, even with the added margins. Note that all resampled images (in both the ``FUSE/FUSE_RELEASE`` and the ``SEG/SEG_RELEASE`` directories have the same geometry than the template image. .. _tutorial-properties-seg: Sequence properties computation [1] ----------------------------------- We assume that we are located in the directory ``/path/to/astec-tutorial/``. Computing cell properties as well as lineage assumes that segmentation or post-corrected segmentation (see section :ref:`tutorial-properties-post`) images have been co-registered (see sections :ref:`tutorial-intra-registration-seg` and :ref:`tutorial-intra-registration-post`). Extracting the sequence properties from the co-registered segmentation images is done with .. code-block:: bash $ astec_embryoproperties -p parameters/X-embryoproperties-tutorial-parameters-seg.py ``X-embryoproperties-tutorial-parameters-seg.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-properties-seg`). .. code-block:: python :linenos: :caption: parameter file for sequence properties computation from the co-registered segmentation images. :name: fig-tutorial-parameter-properties-seg PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 EXP_INTRAREG = 'SEG' * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``FUSE/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variables ``begin`` and ``end`` set respectively the first and the last index of the input time points to be processed. * the variable ``EXP_INTRAREG`` set the suffix of the sub-directory of the ``INTRAREG/`` directory where to search post-corrected segmentation or segmentation images. Since the directory ``INTRAREG/INTRAREG_SEG/`` only contains the co-registered segmentation images (in the ``SEG/SEG_RELEASE/`` sub-directory), properties will be computed from these images. After processing, some files appears in the ``INTRAREG/INTRAREG_SEG/SEG/SEG_RELEASE/`` sub-directory .. code-block:: none INTRAREG/ ├── INTRAREG_RELEASE/ └── INTRAREG_SEG/ ├── CO-TRSFS/ │ └── ... ├── FUSE/ │ └── ... ├── LOGS/ ├── MOVIES/ │ └── ... ├── SEG/ │ └── SEG_RELEASE/ │ ├── 2019-Tutorial100_intrareg_seg_lineage.pkl │ ├── 2019-Tutorial100_intrareg_seg_lineage.tlp │ ├── 2019-Tutorial100_intrareg_seg_lineage.txt │ ├── 2019-Tutorial100_intrareg_seg_lineage.xml │ ├── 2019-Tutorial100_intrareg_seg_t000.mha │ ├── ... │ └── 2019-Tutorial100_intrareg_seg_t020.mha ├── TRSFS_t0-20/ │ └── ... ├── ... └── LOGS/ ``2019-Tutorial100_intrareg_seg_lineage.pkl`` is a pickle python file containing a dictionary (in the python sense). It can be read by .. code-block:: $ python ... >>> import pickle as pkl >>> f=open('2019-Tutorial100_intrareg_seg_lineage.pkl', 'r') >>> d = pkl.load(f) >>> f.close() >>> d.keys() ['all_cells', 'cell_barycenter', 'cell_contact_surface', 'cell_principal_vectors', 'cell_principal_values', 'cell_volume', 'cell_compactness', 'cell_surface', 'cell_lineage'] In this pickle file (as in the one computed at section :ref:`tutorial-segmentation-propagation`), cells have an unique identifier :math:`i * 1000 + c`, which is made of both the image index :math:`i` and the cell identifier :math:`c` within a segmentation image (recall that cells are numbered from 2, 1 being the background label). ``2019-Tutorial100_intrareg_seg_lineage.xml`` contains the same information than the pickle file, but in xml format (see figure \ref{fig:tutorial:seg:properties:xml}). .. code-block:: none :caption: XML output properties file from the co-registered segmentation images :name: fig-tutorial-seg-properties-xml ... ... ... ... ... ... ... [2, 3, 4, 5, 6, 7, 8, 11, 12, 13, ... 200097, 200099, 200100, 200101, 200102] ... ``2019-Tutorial100_intrareg_seg_lineage.tst`` contains some *diagnosis* information (smallest and largest cells, weird lineages, etc.). .. _tutorial-post-segmentation: Segmentation post-correction ---------------------------- We assume that we are located in the directory ``/path/to/astec-tutorial/``. Segmentation post-correction is done with .. code-block:: bash $ astec_postcorrection -p parameters/5-postcorrection-tutorial-parameters.py ``5-postcorrection-tutorial-parameters.py`` being the dedicated parameter file (figure :ref:`fig-tutorial-parameter-post-correction`). .. code-block:: python :linenos: :caption: parameter file for the segmentation post-correction. :name: fig-tutorial-parameter-post-correction PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 result_lineage_suffix = 'pkl' After processing, a ``POST/`` directory has been created .. code-block:: none /path/to/astec-tutorial/ ├── FUSE/ ├── INTRAREG/ ├── SEG/ ├── POST/ ├── data/ ├── ... ├── parameters ... The ``POST/`` directory contains .. code-block:: none POST/ └── POST_RELEASE/ ├── 2019-Tutorial100_post_lineage.pkl ├── 2019-Tutorial100_post_t000.mha ├── ... ├── 2019-Tutorial100_post_t020.mha └── LOGS/ .. _tutorial-intra-registration-post: Sequence intra-registration (or drift compensation) [3] ------------------------------------------------------- We assume that we are located in the directory ``/path/to/astec-tutorial/``. Running the sequence intra-registration is done with .. code-block:: bash $ astec_intraregistration -p parameters/1.5-intraregistration-tutorial-parameters-post.py ``1.5-intraregistration-tutorial-parameters-post.py`` being the dedicated parameter file (figure :ref:`fig-tutorial-parameter-intra-registration-post`). .. code-block:: python :linenos: :caption: parameter file for the motion compensation step, post-segmentation images being used to build the template. :name: fig-tutorial-parameter-intra-registration-post PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 EXP_INTRAREG = 'SEG' intra_registration_template_type = "POST-SEGMENTATION" intra_registration_template_threshold = 2 intra_registration_margin = 20 intra_registration_resample_segmentation_images = True intra_registration_movie_segmentation_images = True intra_registration_movie_post_segmentation_images = True intra_registration_movie_segmentation_images = True * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``FUSE/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variables ``begin`` and ``end`` set respectively the first and the last index of the input time points to be processed. * the variable ``EXP_INTRAREG`` set the suffix of the sub-directory of the ``INTRAREG/`` directory to be created. * the variable ``intra_registration_template_type`` set the images to be used to build the template. Here, since it is equal to ``"POST-SEGMENTATION''``, they are the post-corrected segmentation images obtained at the previous step. The variable ``intra_registration_template_threshold`` set a threshold to be applied to the template images to define the information to be kept: we want all the points with a value equal or greater than 2 to be contained in the template after resampling. Since cells are labeled from 2 and above, the template is designed to contain all labeled cells after resampling, so it is built as small as possible. The variable ``intra_registration_margin`` allows to add margins (in the 3 dimensions) to the built template. * The variable ``intra_registration_resample_post_segmentation_images`` indicates whether the post-corrected segmentation images are to be resampled in the template geometry. * The variable ``intra_registration_resample_segmentation_images`` indicates whether the segmentation images are to be resampled in the template geometry. * The variable ``intra_registration_movie_post_segmentation_images`` indicates whether 2D+t movies have to be built from the resampled post-corrected segmentation images. * The variable ``intra_registration_movie_segmentation_images`` indicates whether 2D+t movies have to be built from the resampled segmentation images. After processing, a ``INTRAREG/INTRAREG_POST/`` directory has been created and the ``INTRAREG/`` directory now contains .. code-block:: none INTRAREG/ ├── INTRAREG_RELEASE/ ├── INTRAREG_POST/ │ ├── CO-TRSFS/ │ │ ├── 2019-Tutorial100_intrareg_flo000_ref001.trsf │ │ ├── ... │ │ └── 2019-Tutorial100_intrareg_flo019_ref020.trsf │ ├── FUSE/ │ │ └── FUSE_RELEASE/ │ │ ├── 2019-Tutorial100_intrareg_fuse_t000.mha │ │ ├── ... │ │ └── 2019-Tutorial100_intrareg_fuse_t020.mha │ ├── LOGS/ │ ├── MOVIES/ │ │ ├── FUSE/ │ │ │ └── FUSE_RELEASE/ │ │ │ └── 2019-Tutorial100_intrareg_fuse_t000-020_xy174.mha │ │ ├── POST/ │ │ │ └── POST_RELEASE/ │ │ │ └── 2019-Tutorial100_intrareg_post_t000-020_xy174.mha │ │ └── SEG/ │ │ └── SEG_RELEASE/ │ │ └── 2019-Tutorial100_intrareg_seg_t000-020_xy174.mha │ ├── POST/ │ │ └── POST_RELEASE/ │ │ ├── 2019-Tutorial100_intrareg_post_t000.mha │ │ ├── ... │ │ └── 2019-Tutorial100_intrareg_pst_t020.mha │ ├── SEG/ │ │ └── SEG_RELEASE/ │ │ ├── 2019-Tutorial100_intrareg_seg_t000.mha │ │ ├── ... │ │ └── 2019-Tutorial100_intrareg_seg_t020.mha │ ├── TRSFS_t0-20/ │ │ ├── 2019-Tutorial100_intrareg_t000.trsf │ │ ├── ... │ │ ├── 2019-Tutorial100_intrareg_t020.trsf │ │ └── template_t0-20.mha │ ├── ... │ └── LOGS/ ├── INTRAREG_RELEASE/ │ └── ... └── INTRAREG_SEG/ └── ... In addition to directories already described in sections :ref:`tutorial-intra-registration-fuse` and :ref:`tutorial-intra-registration-seg`, the ``INTRAREG_POST/`` directory contains * The directory ``POST/POST_RELEASE/`` contains the resampled post-corrected segmentation images in the same geometry (images have the same dimensions along X, Y and Z), with drift compensation (the eventual motion of the sample under the microscope has been compensated). * In addition to a 2D+t movie made from the resampled fusion and the segmentation images, the directory ``MOVIES/`` contains a 2D+t movie made from the resampled post-corrected segmentation images in the sub-directory ``POST/POST_RELEASE/``. * The template image ``template_t0-20.mha`` in the directory ``TRSFS/`` is of size :math:`323 \times 265 \times 348` with a voxel size of 0.6, has the same size than the one computed in section :ref:`tutorial-intra-registration-seg`, which is expected since the post-correction does not change the background. Note that all resampled images (in the ``FUSE/FUSE_RELEASE/``, the ``POST/POST_RELEASE/``, and the ``SEG/SEG_RELEASE/`` directories have the same geometry than the template image. .. _tutorial-properties-post: Sequence properties computation [2] ----------------------------------- We assume that we are located in the directory ``/path/to/astec-tutorial/``. Computing cell properties as well as lineage assumes that segmentation or post-corrected segmentation (see section :ref:`tutorial-post-segmentation`}) images have been co-registered (see sections :ref:`tutorial-intra-registration-fuse` and :ref:`tutorial-intra-registration-seg`). Extracting the sequence properties from the co-registered segmentation images is done with .. code-block:: bash $ astec_embryoproperties -p parameters/X-embryoproperties-tutorial-parameters-post.py ``X-embryoproperties-tutorial-parameters-post.py`` being the dedicated parameter file (listing :numref:`fig-tutorial-parameter-properties-post`). .. code-block:: python :linenos: :caption: parameter file for sequence properties computation from the co-registered post-segmentation images. :name: fig-tutorial-parameter-properties-post PATH_EMBRYO = '.' EN = '2019-Tutorial100' begin = 0 end = 20 EXP_INTRAREG = 'POST' * The variable ``PATH_EMBRYO`` is the path to the directory where the directory ``FUSE/`` is located. It can be either relative (as in the above example) or global (it could have been ``/path/to/astec-tutorial/``). * The variable ``EN`` is the prefix after which the images are named. * The variables ``begin`` and ``end`` set respectively the first and the last index of the input time points to be processed. * the variable ``EXP_INTRAREG`` set the suffix of the sub-directory of the ``INTRAREG/`` directory where to search post-corrected segmentation or segmentation images. Since the directory ``INTRAREG/INTRAREG_POST/`` contains the co-registered post-corrected segmentation images (in the ``POST/POST_RELEASE/`` sub-directory), properties will be computed from these images preferably to the co-registered segmentation images (in the ``SEG/SEG_RELEASE/`` sub-directory). After processing, some files appears in the ``INTRAREG/INTRAREG_POST/POST/`` sub-directory .. code-block:: none INTRAREG/ ├── INTRAREG_POST/ │ ├── CO-TRSFS/ │ │ └── ... │ ├── FUSE/ │ │ └── ... │ ├── LOGS/ │ ├── MOVIES/ │ │ └── ... │ ├── POST/ │ │ └── POST_RELEASE/ │ │ ├── 2019-Tutorial100_intrareg_post_lineage.pkl │ │ ├── 2019-Tutorial100_intrareg_post_lineage.tlp │ │ ├── 2019-Tutorial100_intrareg_post_lineage.txt │ │ ├── 2019-Tutorial100_intrareg_post_lineage.xml │ │ ├── 2019-Tutorial100_intrareg_post_t000.mha │ │ ├── ... │ │ └── 2019-Tutorial100_intrareg_post_t020.mha │ ├── SEG/ │ ├── TRSFS_t0-20/ │ │ └── ... │ ├── ... │ └── LOGS/ ├── INTRAREG_RELEASE/ │ └── ... └── INTRAREG_SEG/ └── ... Those files have the same content than the ones already presented in section :ref:`tutorial-properties-seg`.
